Tekla Structures Model
engineer69
Сообщение engineer69 » 12 май 2013, 21:27
Hi, I want to ask how to scale model in Tekla Structures? For instance: I have 5000 mm but I want to be it 5 mm ?
ilya_kon
Re: Tekla Model
Сообщение ilya_kon » 13 май 2013, 20:27
I do not understand what you mean. Could you please elaborate?
engineer69
Re: Tekla Model
Сообщение engineer69 » 14 май 2013, 01:04
For example: in autocad we have 5 mm line, we bring command SCALE, then write scale factor 1000. Now the line is 5000 mm length. And vice versa: we have 5000 mm line, we bring command SCALE, write scale factor 0.001. Now the line is 5 mm length. Is it possible to do this scale matter with whole model in Tekla?
Re: Tekla Model
Сообщение CuPo>I<a » 14 май 2013, 05:14
in model it's not possible. in drawings and export you can set anyone scale
