Attribute & Stats of Elden Ring Items Gargoyle's Blackblade & Scarlet Aeonia Build
Vigor-60
Mind-50
Endurance-25
Strength-18
Dexterity-13
Intelligence-9
Faith-80
Arcane-7
Equipment of Gargoyle's Blackblade & Scarlet Aeonia Build
Weapon: Gargoyle's Blackblade
Its signature unique skill corpse wax cutter, the weapon itself is really strong if you're probably sat it into the scaling of its overall AR is extremely high, and so the weapon hits are exceptionally meaty, even though that's not really the focus of today's build at all it's more just a side bonus, the general focus is the weapon skill itself, corpse wax cutter, this skill when used fires out in the line in front of you that covers quite a bit of fair distance, and when it hits an enemy, it will both do a fairly large chunk of damage, and apply the black flame debuff to them which is a DOT that does Max Health percentages damage for 2 seconds after the hit connects, providing a good amount of extra bonus damage that scales with the difficulty of the enemy that you're fighting, it's worth noting if of course that the skill was buffed in patch 1.07 as well, reducing its FP consumption to 16, increasing the motion speed range and speed of the attack itself, as well as adding damage detection to the weapon swing part of the ash itself which means that if you use this in melee range you get a weapon hit, the ash of Wars base damage, and then also the health percentage damage over time effect as well, making it quite potent in that range on top of this playing around with the theme and also taking advantage of our attribute splits, we are using the Scarlet Aeonia incantation, mostly as an opener and it does pretty good damage, but the main reason to use this is its application of the Scarlet Rod debuff, one use of this well-timed and we positioned will apply Scarlet rot to most enemies, but there isn't a single enemy or boss in the game that can take two hits of this incantation without getting the debuff, your enemy has Scarlet rot, they'll just be ticking for loads of damage constantly and consistently, so putting that together with your weapon skill is quite fun, on top of this the spell itself was also buffed in patch 1.07 to make it significantly stronger, thus why it functions so well within this build, it was given reduced FP cost increased attack power poise damage and statement attack power against guarding enemies, and the actual Landing of the attack has longer range and decreased recovery time too and they also made the Poise increase of the spell happen earlier in the animation which makes it much safer to cheap Elden Ring Items trade within pretty much any situation, this combination of spell and weapon is extremely strong.
Mmoexp Elden Ring Items: Equipment of Gargoyle's Blackblade & Scarlet Aeonia Build
